FPGA Intellectual Property
6670 Discussions
MegaCore Function Generation error(Dspbuilder)
These days I am doing some examples on dspbuilder, but I have met so many problems. Some have already sloved,some not. I post an problem here:
在Quartus II 7.2sp2 Web Edition中设计fir数字滤波器,当点击IP Toolbench中的Generate时,产生这样的错误:MegaCore Function Generation Error,IP Functionl simulation Model Creation Failed.The following error was returned:Error:specified license does not contain information requered to run the Quartus Ⅱ software.
How to slove it ? I need help!
有时候可以完成generation,有时候就会弹出上面的错误~~我不理解~~难道是我的License有问题吗? MegaCore 需要另外再安装License吗?
--- Quote Start ---
--- Quote End ---
I doubt that you can use DSPBuilder together with the Quartus Web Edition.
Maybe some other people on the forum could clarify this.
不好意思,请您用英文讨论。
should be possible to do DSP Builder and Quartus II web edition:
http://www.altera.com/support/kdb/solutions/rd07262004_7122.html
sorry ,my english is poor. I have already tried my best to discription it in english.But I failed. Maybe I will use pictures to ask questions.
Now i just want to say that my dspbuilder is very unstable.Sometimes it can generate FIR without any errors,sometimes it leads to the questions above. What can I do ? ~~~I hope that you can understand my meaning.
--- Quote Start ---
--- Quote End ---
用母语蛮好。把意思讲清楚就行了。再加一点英文说明。
Speaking our mother language, Chinese, is very good. Some related English to describe the problem you concerned is needed, too.
