FPGA Intellectual Property
6669 Discussions
MultiChannel Serdes on CycloneIV GX problems
Hi all,
I met a problem about multichannel(> 4 ch) serdes design on CycloneIV GX fpga.the generated ALT_GX megacore's source file include a 2-bit width pll_iclk signal,so I connect the 2-bit signal to 2 pins.but,after compile,I found that QuartusII warning says:
Warning: Design contains 1 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "ref_clk[1]"
I'v connect eight data generate module and a alt_reconfig module to the alt_gx module ,so I think maybe somethins wrong?
thx
I attached the test project,hope somebody can help me.
