FPGA Intellectual Property
6669 Discussions
NCO Compiler problem :(
Hi All,
I am trying to generate a sine wave using nco compiler, I am using simulink for the megacore library, when I use it, in matlab promt it say that unable to locate megacore nco 2.2.2
well anyways Then i have three inputs
clkken
phase_inc
reset
output i have
sine
cosine
data ready
So I just have to plug in the 32 bit array to the phase in and
attach a scope to see the output of it right? Am i missing something here ? I just see a straight in my scope
Kindly Help me
DspBoard
Hi DSPBoard,
If I remember NCO correctly... you will have to enable clken, pass a constant value to the phi input (the phi value can be found in the megawizard, after you set all the dithering...etc.) and lastly reset the core. If you do all three, then you should be able to see sine and cosine waves coming out of the core.
Good luck!
