FPGA Intellectual Property
6673 Discussions
Newbie Question: Access DPR outside SOPC Builder
I'm currently having trouble to set up a connection to a megawizard created Dual Port RAM. I want to make it accessible from within NIOS as if it was a normal RAM inside NIOS-II via a DMA memory-to-memory access.
Is there an IP you can use for this type of access ? Do you need any kind of bridge for that? I can't believe that there is no IP for that kind of common issue.
I currently tried to build my "own" interface out of PIOs, but I can't do that because of latency issues, can I ?
See the attachments for further information.
I would highly appreciate your help!
Thx =)
Hi andreg,
I had the same need as you.
Please refer to the following thread I started last month for some ideas:
http://www.alteraforum.com/forum/showthread.php?t=24965
Actually, I eventually ended up with a different and simpler approach.
I instantiated the dpr external to the sopc system and used the sopc tristate bus to access it. In my design this was enough; maybe this is not good for your case if you have strong performance requirements.
Cris
Hi andreg,
I see wrong things in your code. Check if they are only copy and paste errors or actual code errors:
- in alt_dma_rxchan_prepare(), the 4th parameter should be dma_done, namely the pointer to function to be called upon dma completion
- you wait dma completion testing a rx_done variable, but you actually set the other variable dma_complete when dma completes
- are you sure the tx_data and rx_buffer addresses you provide match those of memories connected to tx/rx dma: you should use system.h defines instead of numeric values.
I have a design similar to your one and it works perfectly.
I tried to use your same code (with the above corrections) and the dma performs correctly.
The only differences being:
- dma width is 16bits
- tx dma is from external sram connected to sopc tristate bus
- rx dma is to the main sdram and not a separate onchip memory
(I don't think you need that descriptor memory; you are not using a sgdma module)
Final note: pay attention to define rx_done as volatile, otherwise compiler may assume the while loop never ends.
Cris
Hi andreg,
Probably you have an error in tx_chan address and you are making dma transfer from the wrong memory area..
Is the tristate bus width 32?
well I think I found some kind of reason for the problem.
I changed some settings in the interface tab of the dpr interface (see attachment) and added a clock sink connected from sopc. It seems to work now, I'll figure it out.
Eventually, the attachment can help someone.
Thank you Cris72 for your fast and professional help! =)
