FPGA Intellectual Property
6669 Discussions
OpenCore [I2C_Master_Slave] _Newbie
I am a newbie.
I download I2C_Master_Slave ip core from OpenCore web site.
Then I inport to QuartusII Web Edition,then compiler,I got the error message,below.
"Error (10207): Verilog HDL error at tst_bench_top.v(242): can't resolve reference to object "wb_write"
I read help files.QuartusII Wed Edition support hierarchical node name.
Could someone tell me where are errors.
Program division:
[tst_bench_top.v]
// hookup wishbone master model
wb_master_model# (8, 32) u0 (
.clk(clk),
.rst(rstn),
.adr(adr),
.din(dat_i),
.dout(dat_o),
.cyc(cyc),
.stb(stb),
.we(we),
.sel(),
.ack(ack),
.err(1'b0),
.rty(1'b0)
// program internal registers
u0.wb_write(1, PRER_LO, 8'hfa); // load prescaler lo-byte
//Error
u0.wb_write(1, PRER_LO, 8'hc8); // load prescaler lo-byte
u0.wb_write(1, PRER_HI, 8'h00); // load prescaler hi-byte
[wb_master_model.v]
module wb_master_model(clk, rst, adr, din, dout, cyc, stb, we, sel, ack, err, rty);
task wb_write;
input delay;
integer delay;
input [awidth -1:0] a;
input [dwidth -1:0] d;
begin
// wait initial delay
repeat(delay) @(posedge clk);
// assert wishbone signal
# 1;
adr = a;
dout = d;
cyc = 1'b1;
stb = 1'b1;
we = 1'b1;
sel = {dwidth/8{1'b1}};
@(posedge clk);
// wait for acknowledge from slave
while(~ack) @(posedge clk);
// negate wishbone signals
# 1;
cyc = 1'b0;
stb = 1'bx;
adr = {awidth{1'bx}};
dout = {dwidth{1'bx}};
we = 1'hx;
sel = {dwidth/8{1'bx}};
end
endtask
I have got the VHDL version of this i2c master open core working as a NIOS component.
I am not sure why you have the problem.
I found the following posts useful when I was trying to get it working
http://www.nabble.com/i2c-and-avalon-bus-td17530366.html
http://forum.niosforum.com/forum/lofiversion/index.php/t3583.html
Here is the issue I2C core.
http://www.turboupload.com/download/nzvmqjskhalq/i2c.zip (http://www.turboupload.com/download/nzvmqjskhalq/i2c.zip
Could someone find the issue?
It seems that you try to compile test bench/reference model file(s), which could not be synthesized in Quartus.
Testbench needed ModelSim to parse,not in Quartus.
