FPGA Intellectual Property
OpenCore problem
Hi guys,
I have quartus 7.2 license but I can't use my project without usb cable and quartus running.
Warnings:
Warning: Using OpenCore Plus hardware evaluation for the following cores.
Warning: "Nios II Processor (6AF7_00A2)" will use OpenCore Plus hardware evaluation.
File:
(quartus dosent generate project.pof)
<poject>_time_limited.sof
when quartus finished to program the device, show me a window with time renaming and cancel.
It's normal? (Tethered Mode??)
How can I use that without these restrictions?
Thank you for your help, im noob :)
NIOS (and most commercial IP cores) is licensed separately, but the core will allow you to try it out in a development environment - hence the JTAG tether.
Think of it like shareware, only in hardware.
You will have to buy a NIOS license if you want to run it without a JTAG cable.
If you are in the Altera's University Program, I think you could ask for such a license for free.
I've
finished the last critical fixes I've been planning on putting in OpenCore
0.17.1. Since some of these bugfixes have been quite critical I'd like to
make a release
