FPGA Intellectual Property
6670 Discussions
PCI-E gen3 HIP simulation
Hi
I am having some trouble while simulating the PCI-E gen3 design. As mentioned in the User guide.
1. I ran modelsim
2. source msim_setup.tcl
3. ld
while compiling the files modelsim shows the following errors:
1. faild to open info file "/_info" in read mode
2. Module 'stratix_hssi_gen3_pcie_hip' is not defined
I generated pcie files using Quartus 12 and i am using modelsim 10.1
I believe you have to use Q12.0sp1
Q12.0 still doesn't have BFM in.
I am also facing the same problem with Quartus 12.0 sp1.
For the ip generated through megawizard for verilog, I ran vsim in the <ep>_sim/mentor directory
source msim_setup.tcl in vsim
ld_debug
and I see simulation exiting with errors like
instantiation of stratixiv_hssi_gen3_tx_pcs_encrypted failed. The design unit was not found.
where can find this module?
Alternately, I generated vhdl version of the PCIe core gen 3 and executing the same command ld_debug yielded this error.
Fatal error in a protected context.
Time 0 ps Iteration Protected: /ep_g3_x8_avl_256_a_s5_inst/<protected> File: nofile
FATAL ERROR while loading design
Any ideas/solutions about VHDL simulation failure would be highly appreciated.
Fasahat
