FPGA Intellectual Property
6673 Discussions
PCIe Transmission Problem
I have the Altera Stratix II GX Dev Board.
Im' using the Altera PCIe 9.0 IP Core with Avalon-ST Interface and I ran into some problems.
I transfer 4 MB of data in 128 Byte blocks + header. After about 10 (4MB) transfers the transfer rate decreases till no more transfer is possible.
If I check the avalon interface via SignalTap II I get the results attached to this post. I use 4 lanes (1 VC) and tx_st_ready is always asserted during transfer. But at some point (like I said, after about 7 transfers) tx_st_ready begins to de-assert. It gets worse and worse till it stays at 0 and I'm not able to transfer any more data.
Any idea? The PC uses a Itel DG33TL mainboard (Intel G33 Chipset).
Just in case you are still struggling with this problem, and to inform others who might expierence a similar problem.
The PCI Express specification states that when a malformed TLP is received, flow control information does not have to be updated. Therefore after a few malformed TLPs the transmitter will run out of credits, blocking any further transmissions.
You should check if the TLPs you are sending accord to the specification.
mbadelt,
Were you able to get to the bottom of the issue that you ran into? I am seeing similar, but slightly different behavior. In my case, I chug along at max rate on a gen2 x8 system until I have transmitted about 8kbytes of data in small 128 byte packets. At this point, I have exhausted all of my credits. I do get credit updates, but at a very low rate and only a few at a time. So, my transfer appears to complete, but it slows down dramatically after the first 8kbytes.
Brett,
Did you solve this slowdown problem? I get similiar with SOPC PCIe x1 when DMA to Tx. I am testing with both Intel US15W/Z530 and AMD 785NB/745 Chipsets. The first 1k - 2k is full speed then settles into 16Mbyte/s on US15W and 64Mbyte/s on AMD. I see that it takes Altera's SOPC MM to PCIe bridge 6 clock cycles per QW, so I am running the DMA at 125MHz to compensate, but the PCIe core just pushes back and stalls more clock cycles.
Both platforms run 160Mbyte/s+ with non-SOPC instantiations.
btesar,
The issue that I ran into was system related. The application hardware that I was testing was trying to write the same system address over and over, so the memory controller appeared to be holding me back, as opposed to PCIe. When I switched to a more realistic use case, I saw my transmission rates recover.
brett,
Were you using the SOPC PCIe or Megawizard?
btesar,
I have only used the megawizard for the PCIe IP.
