For the Ptile+PIO example design, with Intel BFM --- in endpoint config, if we replace the PIO instance with CUSTOM_LOGIC, we can perform
- BAR0 ( MemWr, MemRd) --- ( BFM, PTILE_EP---> Custom Logic)
- Similarly, we can also initiate MemWr, MemRd ( Custom Logic ---> PTILE_EP ---> BFMs Shared Memory)
- But in the current BFM, is there a provision to exercise Interrupt ( legacy, MSI/MSI-X)?
链接已复制
Hi Adithiya,
I just try to understand what you going to do before we actually go into your question.
>> Okay, if I understand correctly that will be the reason you using custom logic instead of build in Intel BFM right ?
>> I not sure how you perform your custom logic , but theoretically you can enable these capabilities in your custom BFM instance
>> BUT ensure your custom logic generates the correct signals or memory writes as per the PCIe specification.
Wincent_Altera
Hi ,
Given that there is no any response on this case , I assume you had found the solution somewhere else.
Do let us know back if you need any other help.
Wincent
