FPGA Intellectual Property
6670 Discussions
Problem W/ Altera VIP Frame Buffer II
EvanHamiltonJAVS
I have configured an FPGA design for my linux device that is displaying SDI and HMDI inputs. It was originally configured to receive YCbCr 4:2:2 video format. Since I am experiencing green spill on images when trying to chroma key, I am attempting to change the input data to RGBA.
For a test, I have implemented a conversion into the FPGA that handles the RGB input from the frame buffer. I believe this conversion is correct because the color values come out as expected.
FPGA Design Here:
FB -> CSC -> CRS -> Output
This is the same for all four mixers.
I am using gstreamer to input the color bars pattern into the pipeline.
(gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb3")
There are 4 frame buffers located at "/dev/fb0", "/dev/fb1", and so on.
Basically the issue is these frame buffer's graphics are overlapping and changing the memory regions in the DTS file does not fix the issue:
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb0"
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb1"
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb3"
I can even see the bottom portion of the color bars pattern when changing the height to 720.
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=720 ! videoconvert ! filesink location="/dev/fb3"
The drivers being used for the frame buffer is altvipfb.c and altvipfb2-plat.c
Here is the DTS snippet of these frame buffer components and the boot logs where the frame buffers are initialized:
DTS snippetDTS snippetBoot LogsBoot Logs
The virtual address and length seen in these boot logs do not change at all when DTS changes are made.
I also get this error when inputting a pipeline:
If anyone could help me approach this issue it would be greatly appreciated.
Evan
khtan
Hi Evan,
Thanks for the reply and no worries on the response. Since you're currently tied up with another project, may I know whether possible to set this case to close first, and then once you're free to work on this again, do re-open a new forum thread (if still have any issues) and tag this forum thread link in the new thread so we can trace back the history of the case and support from there on.
Kian
khtan
Hi Evan,
As I could not suspend the thread case tracking in system and being flagged out for idling, I will set this thread to close-pending first and revert to community support. Once you're free up to continue work on this issue, do create a new thread and tag this thread link and we will resume support from there on.
Thanks for using Intel-Altera forums and sorry for the inconvenience cause. Please do let us know once you're able to resume work on this area and still facing issues on the video conversion.
Kian
