FPGA Intellectual Property
6670 Discussions
Problem in implementation of Image Resizer
Hi, I wish to implement the following scaler IP from Altera.
http://www.altera.com/support/examples/dsp-builder/exm-scaler.html
I followed the steps in the following readme text to use the Image Resize example.
ftp://ftp.altera.com/outgoing/download/support/examples/scaler-readme71.txt
I have also installed DSP Builder 7.2 and Quartus II 7.2
However, when i run simulation, I encountered this error
Error reported by S-function 'sGeneric' in 'example/scaler':
An error occurred whilst loading the Cycle Accurate IP / HDL Import simulation netlist DSPBuilder_example_import\scaler.vo. Please regenerate the corresponding block.
Furthermore, when I tried to open the scaler block, I had this error
"Error evaluating 'OpenFcn' callback of MegaCore AlteraBlockset block (mask) 'example/scaler'. Error using ==> testscan
First input can not be empty.
Please advise me on this. Thank you. I hope to be able to generate the output video from this resizer using the tools.
Hi mobiusx,
I think the models online are for 7.1, therefore, not quite compatible with your 7.2. However, the model looks like a pretty simple one and shouldn't be too hard to upgrade to 7.2... Please feel free to ask if you need help.
Please find the updated model for 7.2.
Hope this helps.
thanks alot! for that updated example
I have tried it out but the problem is that it has been scaling for more than 12 hours.
Does it take that long to do so?
