FPGA Intellectual Property
6673 Discussions
Quartus fit cannot place periphery error PCIe PIPE direct mode
ASiu0
OS: Win 11 Pro
Quartus: Prime Pro 22.4.0 Build 94
EVB: Agilex I-series (DK-DEV-AGI027RES)
I intend to build a  PCIe solution by connecting my self-developed PCIe controller to Agilex R-tile PCIe IP in PIPE direct mode. When I generate the bit stream Quartus prompt an error "The Fitter cannot place 3 periphery component(s) ..". I check my pin assignment with the "pipe_ed" example design of Agilex development board (agilex_agib027r29a1e2vr3_fpga_revb_v22.4b94_v1.1) download from Altera web-site and could not find any error. I stuck in this situation for more than 1 week.
Please provide some advice for fix the issue.
Attach herewith a zip file contain *.sv, *.rpt file and *.qsys for your kind reference.
BR,
Albert
skbeh
Hi Albert Siu
Apologize for the late respond.
Here I've attached a demo design which PIPE interface that also targeting AGIB027R29A1E2VR0, this design can compile successfully in Quartus 22.4. You can use it as reference and compare it with your design.
Hope this helps.
skbeh
skbeh
Attached the design.
ASiu0
I will reference to your demo design and update my code to test again.
Thx.
