FPGA Intellectual Property
6669 Discussions
Question about simulation of VIP cores
I'm doing a simulation of Clocked Video Input with Altera-Modelsim using NativeLink, but it seems the IP cores doesn't respond to my testbench as the attachment below, while I have successfully simulated the reconfiguration of altera's pll.
My question is that if the VIP cores support simulation or not, are there any differences between simulation of CVI and PLL?
Thanks for reply!
--- Quote Start ---
Thanks for reply!
--- Quote End ---
how does your testbench lookslike ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hi, GPK
I have attached my testbench, thanks for help!
--- Quote Start ---
Hi, GPK
--- Quote End ---
are you using a synchronous reset ? It looks to me that in your testbench the clocks starts after releasing the reset.
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hi, GPK
As quoted from the VIP user guide, "The MegaCore function is asynchronously reset when rst is asserted high. The reset must be de-asserted synchronously with respect to the rising edge of the is_clk signal."
And I have commented the delay for the clocks initial as below, but it still doesn't work.
Thanks again!
initial
begin
dclk_in = 0;
//#120;
forever# 25 dclk_in = ~dclk_in;
end
initial
begin
sys_clk = 0;
//#120;
forever# 5 sys_clk = ~sys_clk;
end
--- Quote Start ---
Hi, GPK
Thanks again!
initial
begin
dclk_in = 0;
//#120;
end
initial
begin
sys_clk = 0;
//#120;
end
--- Quote End ---
to be honest I was not convinced that the reset is the root cause, but you never know ....
In my experience HiZ often means that nothing is connected to the outputs. Do run a complete Quartus P&R. If yes did you some strange messages that something is missing ??? Or have your core tri-state capable outputs ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hi, GPK
Yes, I did P&R, but no strange messages turned out. Do you have any other suggestions?
Thanks again.
--- Quote Start ---
Hi, GPK
Thanks again.
--- Quote End ---
is it possible for you to look deeper into the IP block, in order to find out whether there are parts of the block running ?
BTW: I found this remark in the documentation
RTL Simulation Reports Errors When Using Verilog HDL
EDA RTL simulation started from the Quartus II software reports errors in the
ModelSim® simulator for designs containing Video and Image Processing Suite
MegaCore functions when the output files are in Verilog HDL.
Affected Configurations
This issue affects configurations that use NativeLink to run a ModelSim simulation
from Verilog HDL.
Design Impact
An error message reports that software cannot find the Altera library.
Workaround
Compile the file db/alt_cusp90_package.vhd to the Altera library. To perform this
compilation, modify the top-level .do script in the simulation/modelsim directory.
Solution Status
This issue will be fixed in a future version of the Video and Image Processing Suite.
Kind regards
GPK
