FPGA Intellectual Property
6670 Discussions
Reed-Solomon IP control signal
hello everyone:
I use reed-solomon IPcore when I encounter problems.
I dont konw how to generate the "source_ena" signal,which is a data output enable signal.I have read the reed-solomon compiler user guide ,but still a litte confused ,I dont konw how to set the "source_ena"signal.I just want to use the R-S IP correctely.please give me some directions,thank you.
soure_ena must be set '1' or controlled by the part which is used to receive or catch the output of the R-S modle.
That 's it.
