FPGA Intellectual Property
SAA7113+VIP need help
hi,everybody.i use saa7113+clocked vedio in+clock vedio out+sdi tx,it not work.I just connect saa7113 VPO[0:7] to the clocked vedio in, and connect LLC to the cloked vedio valid clk,clocked vedio in and clocked vedio out in the QSYS,clocked vedio out connect to sdi tx data,I use a pll to generate 270M to the SDI ipcore.I did'n see any image.what can i do? thanks !
