FPGA Intellectual Property
SOPC PWM Module
I would like to add some PWM outputs to my NIOS system. I could not find a module in the SOPC builder and hardly anything on the web. It is somehow unbelievable that not many users need PWM outputs on their microprozessors.
Pls give me advise how to proceed.
Wolfgang
P.S.: I only post this message in the IP Discussion, because the NIOS forum is obiously down.
I make a simple pwm module (only 1 output).
is in use in a cyclone III, without problems.
3 modules:
pwm.v
//modulo generador PWM
//toni salguero
//inicio: 15 de junio de 2009
module pwm(
rst_n,
clk,
//bus avalon
av_cs,
av_rd,
av_wr,
av_datain,
av_dataout,
av_addr,
//señal de salida PWM
pwm_out
input rst_n;
input clk;
//bus avalon
input av_cs;
input av_rd;
input av_wr;
input [1:0]av_addr;
input [31:0]av_datain;
output [31:0]av_dataout;
output pwm_out;
wire pwm_enable;
wire [15:0]pwm_divisor;
wire [7:0] pwm_width;
pwm_avalon_slave_if pwmif (rst_n, clk, av_cs, av_rd, av_wr, av_addr, av_datain, av_dataout, pwm_enable, pwm_divisor, pwm_width);
pwm_control pwmc (rst_n, clk, pwm_enable, pwm_divisor, pwm_width, pwm_out);
endmodule
pwm_control.v
//modulo de control del pwm
//toni salguero
module pwm_control(
rst_n,
clk,
pwm_enable,
pwm_divisor,
pwm_width,
pwm_out
input rst_n;
input clk;
input pwm_enable;
input [15:0]pwm_divisor;
input [7:0]pwm_width;
output pwm_out;
wire pwm_clk;
reg [7:0]contador;
reg [15:0]clk_div;
//generador del clock del modulo
always @ (posedge clk or negedge rst_n)
begin
if(~rst_n)
begin
clk_div <= 0;
end
else
if(pwm_enable)
begin
clk_div <= clk_div+1;
if(clk_div == pwm_divisor)
begin
clk_div <= 0;
end
end
end
assign pwm_clk = (clk_div == 0 ) ? 1'b1 : 1'b0;
//señal de salida
if(~rst_n)
begin
contador <= 0;
end
else
if(pwm_enable)
begin
if(pwm_clk)
contador <= contador+1;
end
else
contador <= 0;
assign pwm_out = (contador <= pwm_width) ? 1'b1: 1'b0;
endmodule
pwm_avalon_slave_if.v
//interficie con el bus avalon
//toni salguero
module pwm_avalon_slave_if(
rst_n,
clk,
chipselect,
read_n,
write_n,
address,
writedata,
readdata,
pwm_enable,
pwm_divisor,
pwm_width
input rst_n;
input clk;
input chipselect;
input read_n;
input write_n;
input [1:0]address;
input [31:0]writedata;
output [31:0]readdata;
output pwm_enable;
output [15:0]pwm_divisor;
output [7:0]pwm_width;
reg delayed_cs;
reg pwm_enable;
reg [15:0]pwm_divisor;
reg [7:0]pwm_width;
wire cs;
//retardo de cs
if(~rst_n)
delayed_cs <= 0;
else
delayed_cs <= chipselect;
assign cs = chipselect & ~delayed_cs;
//carga datos en el registro de control
if (~rst_n)
begin
pwm_enable <= 0;
pwm_divisor <= 0;
pwm_width <= 0;
end
else if (cs & ~write_n & (address == 0))
begin
pwm_width <= writedata[7:0];
end
else if (cs & ~write_n & (address == 1))
begin
pwm_enable <= writedata[31];
pwm_divisor <= writedata[15:0];
end
//lectura de los datos
//datos de salida
assign readdata = 32'b0
| {32{(~read_n & chipselect & (address == 0))}} & {24'b0, pwm_width}
| {32{(~read_n & chipselect & (address == 1))}} & {pwm_enable, 15'b0, pwm_divisor};
endmodule
Toni Salguero
--- Quote Start ---
I would like to add some PWM outputs to my NIOS system. I could not find a module in the SOPC builder and hardly anything on the web. ..
--- Quote End ---
You should read close topic (http://www.alteraforum.com/forum/showthread.php?t=5892). There is link to literature there. And I attached component with PWM outputs to SOPC (systemavalon_slave_pwm.zip)
