FPGA Intellectual Property
6673 Discussions
Set up for LVDS SERDES IP for Cyclone 10 GX, need 96 TX with 16 CLKs.
KRoma6
I am using the platform designer to set up LVDS SERDES on the Cyclone 10 GX. I have 118 available LVDS channels but the IP is only allowing me to use 72 channels. I need 96 TX outputs with 16 CLKs (1 CLK per 6 TX). Is there a way to set this up or is there some sort of restriction?
YuanLi_S_Intel
Hi Kyle,
Is there any error message for this? Also, what is the OPN that you are using?
Thank You.
KRoma6
Would I be able to create another instance of this IP to reach my desired length?
The OPN is: 10CX220YF780E5G
Here is the Error Message that pops up in IP Parameter editor or Platform Designer:
YuanLi_S_Intel
Hi Kyle,
This message indicates that yo have already used up all the channel in a IP already. Can you try create another LVDS IP instance?
Thank You
