FPGA Intellectual Property
6669 Discussions
Simulation error caused by S-function
I am trying to simulate sample example of DSP builder. But when i start simulation, some errors occured depending on S-function parameters.
Here you can find the type of errors seen in Simulink:
S-function parameter count mismatch. S-function sInOut in singen/SinIn is expecting 0 parameters while 8 were provided in the dialog box.
End error seen in MATLAB:
Error in block : singen/SinIn
Java exception occurred:
com.altera.dspbuilder.simulation.templates.BlockTemplateException: Error creating block template : com.altera.dspbuilder.blockset.iobus.Input
at com.altera.dspbuilder.simulation.templates.BlockXMLParser.createBlock(Unknown Source)
at com.altera.dspbuilder.simulation.templates.BlockXMLParser.getBlockTemplate(Unknown Source)
..and goes down like that
I tried with MATLAB 2007b and 2008b with DSP Builder v8.1, but it doesn't simulate....
I don't get how to I solve this issue and I can't find any related/reported problems on the forum
please help
Thank you...
Enes
You can also send your solution directly to my e-mail:
enes.dilcan@gmail.com
Can you give the rest of that stack trace? Annoyingly I think the relevant bit may be further down.
This is the result of getting started tutorial of DSPB which is named "singen"
All blocks which are inserted from DSP Builder Library to model file are given following error type
=> S-function parameter count mismatch. S-function sInOut in singen/SinIn is expecting 0 parameters while 8 were provided in the dialog box
Sorry, but I don't understand exactly what you wonder?
You said:
--- Quote Start ---
com.altera.dspbuilder.simulation.templates.BlockTe mplateException: Error creating block template : com.altera.dspbuilder.blockset.iobus.Input
at com.altera.dspbuilder.simulation.templates.BlockXM LParser.createBlock(Unknown Source)
at com.altera.dspbuilder.simulation.templates.BlockXM LParser.getBlockTemplate(Unknown Source)
--- Quote End ---
I'd like to see the bit replaced by "... and goes down like that"
Error in block : singen/BusBuild
java.lang.IllegalArgumentException: No enum const class com.altera.dspbuilder.simulation.ExtendedDirection.İNPORT
at java.lang.Enum.valueOf(Unknown Source)
at com.altera.dspbuilder.simulation.ExtendedDirection.valueOf(Unknown Source)
at com.altera.dspbuilder.simulation.templates.BlockXMLParser.addPortToBlock(Unknown Source)
at com.altera.dspbuilder.simulation.BlockFactory.getBlockTemplate(Unknown Source)
at com.altera.dspbuilder.simulation.Factory.createBlock(Unknown Source)
at com.altera.dspbuilder.simulation.Model.createBlock(Unknown Source)
at com.altera.dspbuilder.simulation.Cache.createBlock(Unknown Source)
at com.altera.dspbuilder.simulation.Mask.updateGUI(Unknown Source)
In addition to this, errors are seen in MATLAB command window for each blocks that give S-function error in Simulink
It seems to me that your DSPB installation is corrupt.
The forum is mangling the text a little bit, so I'm not sure. Where it says "No enum const class com.altera.dspbuilder.simulation.ExtendedDirection.INPORT", on my screen the "I" is coming up as either İ or if I change the encoding to an I with a dot above it. Either way this is not good.
Can you confirm exactly what the text looks like on your screen. Try manually adding spaces in between each of the words separated by full stops - this should stop the forum doing its own thing.
