FPGA Intellectual Property
6673 Discussions
Soft LVDS IP core bitslip
SMS
I am using Max10 and included Soft LVDS IP core for data transmission and reception. For link training I sent 8'h0F. Now, the data at LVDS Rx slips every clock cycle.
LVDS_IP_core_bitslip_(ext_pll).PNGI have tried to align it using the rx_data_align but that does not resolve the issue. LVDS IP was configured as:
General:
Power Supply Mode: Single Supply (for 10M16SAE144I7G)
Functional Mode: Rx
No. of channels: 1
SERDES factor: 8
PLL Settings:
Use external PLL (checked)
Receiver Settings:
Enable bitslip mode (checked)
Bitslip rollover value: 1
I have also tried to use internal PLL in which case the the bitslip occurs at random intervals. Now how can I fix this issue?
IDeyn
New Contributor III
Hi SMS,
It is a strange behaviour - in case align is stable you shouldn't get bitslip as it is on first figure.
You could attach your project in order for community to check it.
Ivan
SMS
Attached are two projects one for Tx and one for Rx. I am programming the DE10-Lite board (10MDAF484C7G) as Tx and a custom board (10M16SAE144I7G) as Rx.
IDeyn
New Contributor III
Hi SMS,
I quickly checked your project and I can say that you should begin with a creation of constraint file (sdc).
You should start with create_clock command, FE create_clock -name {I_ADC_FCO} -period 20.000 -waveform { 0.000 10.000 } [get_ports {I_ADC_FCO}]
After that and after successful timing analysis you should test if your design works.
Ivan
