FPGA Intellectual Property
6670 Discussions
Switching between layers
Hi all,
I have designed a video processing application by using VIP cores. I have 3 layers and I want to switch between layers.It means that I want to change the video in front of other layers.How can I do that.In the user manual of the vip suite it is said that switch and control synchronizer will be used with alpha blending mixer.I have did all the things said in the manual but could not manage. Is there anyone managed switching between layers?
Can you please explain in details the problem you have?
Following the VIP user manual 10.1 Figure 5–28. "Example of a layer Switching System" should work fine.
BR,
Reuven
