FPGA Intellectual Property
6670 Discussions
TLP request with Root port to endpoint
ALast5
I had a problem with the Read Config Type 0 request from the Root port to the endpoint
I use the CRA interface and my query is
32'h 04000001
32'h0000170F
32'h00000000
32'h00000000
I use one endpoint and one communication line, cfg_bus [12: 0] on both devices shows 13'd0.
Ltssmstate [4: 0] takes the value 0x0F and lane_act [3: 0] takes 0x01.
The problem is that when sending a request from the Root port, it receives it and responds to it (gives its configuration space to the Root port) and the data does not reach the endpoint, I use Cyclone 5, tell me what could be the problem?
KeenYewL_Intel
Hi there, sorry for being late, we will find someone to address your question.
BoonT_Intel
Hi Sir,
Let me clarify, do you mean the endpoint is ack with the config_read request but never return a data?
ALast5
That's right, as I understand it, this is connected with routing, but apparently I don’t understand how to use it correctly, or is it connected with "enumeration"?
Sorry for my bad english
Sincerely, Alexander
BoonT_Intel
Hi Sir,
can you help to show us fro where you observe the ACK and waiting for the data? Do you try with other address? Also, if you perform memory read, will you facing the same issue?
Yes, usually config_read/write is happen during enumeration automatically, user do not need to trigger it manually. May I know is the enumeration is complete at the root port?
ALast5
I probably did not say so. I'm on the Root port side. I'm trying to get device configuration space. I guess I do not completely do enumration.
BoonT_Intel
Hi, Ltssmstate [4: 0] takes the value 0x0F and lane_act [3: 0] takes 0x01. show the link are up. with this we can assume the enumeration is completely done.
can you give a try on doing same config read to other endpoint? Or try with different address
ALast5
Unfortunately, there is no possibility to use another endpoint. How to configure routing? To use queries Read Config Type 1?
BoonT_Intel
Routing done by header 0 and header 1.
Header 0 is for endpoints (device) while header 1 is for rootcomplex, SWs and bridges.
ALast5
Solved a problem
First, I assigned the device number and bus number
0x44000001
0x0000100F
0x00000018
0x00010100
and then done the configuration read type 1
0x05000001
0x0000100F
0x01080000
0x00000000
thanks for the help
BoonT_Intel
Hi Sir,
Glad to know it is solve.
Can you help by briefly explain how you decode these:
0x44000001
0x0000100F
0x00000018
0x00010100
0x05000001
0x0000100F
0x01080000
0x00000000
This may help others whose using CRA interface.
