FPGA Intellectual Property
6664 Discussions
TSE GMII gmii_rx_dv without data_rx_valid signal
Zarquin
New Contributor II
Dear Community,
I am using the Triple Speed Ethernet IP Core with the GMII interface on a board with a Cyclone 10GX220.
The TSE MAC command register was initialised with:
0x2033 (SW Reset, Pad En, Promis En, RX En, TX En)
When I send a UDP Broadcast packet from the PC to the board, the packet is
visible on the GMII RX lines coming from PHY (see figure below). But data do not (or only sporadically) arrive on the Avalon-ST RX bus (see illustration) .
What could be the reason for this?
Fig.
I have connected the TSE mac according to this illustration.
The lan used has 1000Mbps.
In the rare cases where the data received via GMII arrives on the Avalon-ST RX bus, it looks like this: 
This is it should always look like!
Zarquin
New Contributor II
In the meantime i think it is a timing problem.
I will open a new post for this.
Zarquin
New Contributor II
paveetirrasrie_Intel
Hi Zarquin,
I'm glad that you've found the rootcause.
I just want to confirm with the dialogue box, so if you closed the dialogue box, TSE IP doesn't work as intended?
pavee
Zarquin
New Contributor II
Hi Pavee,
yes, when the dialogue is closed, the TSE IP Core stops working.
Zarquin
Hi Zarquin,
Thanks for confirming.
I’m glad that your question has been addressed, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
