FPGA Intellectual Property
TSE reference design
Hi everybody,
I am working with the TSE reference design from altera. The TSE include a MAC block, PCS and PMA.
When I use optic SFP, in loopback, everything works well. I would like to work with Copper SFP. But when I use them, it doesn't work.
The autonegociation 1000BASE-X is never complete. I tried to disable this autonegociation, thanks to the TSE_PCS_CONTROL register. When I do that, It seems to send packets, but in fact I think nothing happens, I have the following registers:
DEBUG -- premiere verif MAC_CMD_CONFIG => 0x623
DEBUG -- EMON1- Receiving Packets = 1000000
DEBUG -- EGEN1- Sending Packets = 1000000
DEBUG -- EGEN0- Configuration Setting = 0xbdc
DEBUG -- EGEN0- Seed Value High = 0x2914
DEBUG -- EGEN0- Seed Value Low = 0x54e59c61
DEBUG -- EGEN0- MAC SRC ADDR High = 0xee11
DEBUG -- EGEN0- MAC SRC ADDR Low = 0x22334450
DEBUG -- EGEN0- MAC DST ADDR High = 0xee22
DEBUG -- EGEN0- MAC DST ADDR Low = 0x33445560
DEBUG -- EMON1- RX CTL STAT = 0x1
DEBUG -- EGEN0- OPERATION = 0x1
and for the report, I have an error message:
Number: 1
Status: Error (monitor never finished; please re-download SOF to reset
system)
Run Time: 0.000 seconds
-----Link Configuration-----
TSE Sender MAC: 0xee1122334450
TSE Receiver MAC: 0xee2233445560
Link Speed: 100 (Duplex: half)
-----Sender-----
Packets to Send: 1000000 packets
(length: 1518, data type: increment)
Packets Sent: 1000000 packets (NaN packets/sec)
-----Receiver-----
Packets Received: 0 (valid: 0, error: 0)
Bytes Received: 0 bytes (rate: NaN bits/second)
I also change SFP registers, but it doesn't change anything.
Are there other registers to change?
Does anybody have an idea to help me??
Thank you for your help!!
Hi celine_86
I am having same issue with TSE reference design and it would great if you could share your experiences/pointers in solving the issue.
Thanks in advance.
