Hi everybody,
I am working with the TSE reference design from altera. The TSE include a MAC block, PCS and PMA. When I use optic SFP, in loopback, everything works well. I would like to work with Copper SFP. But when I use them, it doesn't work. The autonegociation 1000BASE-X is never complete. I tried to disable this autonegociation, thanks to the TSE_PCS_CONTROL register. When I do that, It seems to send packets, but in fact I think nothing happens, I have the following registers: DEBUG -- premiere verif MAC_CMD_CONFIG => 0x623 DEBUG -- premiere verif MAC_CMD_CONFIG => 0x623 DEBUG -- EMON1- Receiving Packets = 1000000 DEBUG -- EGEN1- Sending Packets = 1000000 DEBUG -- EGEN0- Configuration Setting = 0xbdc DEBUG -- EGEN0- Seed Value High = 0x2914 DEBUG -- EGEN0- Seed Value Low = 0x54e59c61 DEBUG -- EGEN0- MAC SRC ADDR High = 0xee11 DEBUG -- EGEN0- MAC SRC ADDR Low = 0x22334450 DEBUG -- EGEN0- MAC DST ADDR High = 0xee22 DEBUG -- EGEN0- MAC DST ADDR Low = 0x33445560 DEBUG -- EMON1- RX CTL STAT = 0x1 DEBUG -- EGEN0- OPERATION = 0x1 and for the report, I have an error message: Number: 1 Status: Error (monitor never finished; please re-download SOF to reset system) Run Time: 0.000 seconds -----Link Configuration----- TSE Sender MAC: 0xee1122334450 TSE Receiver MAC: 0xee2233445560 Link Speed: 100 (Duplex: half) -----Sender----- Packets to Send: 1000000 packets (length: 1518, data type: increment) Packets Sent: 1000000 packets (NaN packets/sec) -----Receiver----- Packets Received: 0 (valid: 0, error: 0) Bytes Received: 0 bytes (rate: NaN bits/second) I also change SFP registers, but it doesn't change anything. Are there other registers to change? Does anybody have an idea to help me?? Thank you for your help!!Link Copied
Hi celine_86
I am having same issue with TSE reference design and it would great if you could share your experiences/pointers in solving the issue. Thanks in advance.
