FPGA Intellectual Property
6673 Discussions
Test pattern generator from the Altera VIP suite
there seems to be a problem with the test pattern generator in conjunction with Quartus 13.1.
When I run elaboration Quartus fails because the TPG component does not contain any ports.
When I run the block symbol creator an empty block is created.
The same TPG design does work with Quartus 13.0sp1.
Jan
