FPGA Intellectual Property
6673 Discussions
Tristate bridge can't read data
I have a problem with a tristate bridge which intefaces between Nios and a few ram devices external to the sopc system.
I can correctly write data to the devices but I can't read anything: reads always return all ones.
Data is correctly driven onto the bus. I SignalProbed the the_tristate_bridge_avalon_slave|internal_incoming_tristate_bridge_data
lines and I see that data levels are correct up here.
The problem seems to be in bridging data to Avalon bus.
The strange thing is that I copied the design from a former project where everything worked fine: I simply changed something inside the sopc; anyway the tristate bridge module is the same as before, including tristate devices base addresses.
Any ideas? Thank you in advance.
Cris
Could it be a timing problem? If you didn't specify the correct number of read wait states for your external components, the data could be correct but arrive too soon or too late.
Hi Daixiwen,
The same configuration always worked in the previous project, and I changed it recompiled a lot of times in the past.
Now I simply copied that project, changed something not related to the bridge and recompiled for a new hardware.
Moreover the current target has a better speed grade (-6 vs -8), so I expected it would be even less critical. Am I right supposing this?
I will now follow your advice and I'll try to increase the wait states, in order to test if the problem is here.
I eventually found the problem.
The hold time was nearly zero: when tristate bus deasserted rd signal the data was immediately removed from the bus; that's because the device was actually onchip ram and not a real tristate slave.
Indeed the problem was triggered by the faster device: the previous one probably introduced a small hold time which has hidden the problem until now.
