FPGA Intellectual Property
6670 Discussions
Using multiple LPMs of same type but different characteristics
Hi all,
I was trying to find a way to use the sam LPM Megafunction but with different settings. For example, the lpm_add_sub function, I would like to have both an adder and subtractor but can't figure it out.
- Here's an example
COMPONENT lpm_sub
GENERIC ( lpm_direction : STRING := "ADD";
lpm_hint : STRING := "ONE_INPUT_IS_CONSTANT=NO,CIN_USED=NO";
lpm_representation : STRING := "SIGNED";
lpm_type : STRING := "LPM_ADD_SUB";
lpm_width : NATURAL := 32
PORT ( dataa : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
END COMPONENT;
- and then instantiate it with:
lpm_sub_component : lpm_sub
PORT MAP ( a, c, result_sub );
- I get
Error: Node instance "lpm_sub_component" instantiates undefined entity "lpm_sub"
So it appears the component name has to be that of the lpm function. What is the use of the LPM_TYPE characteristic then?
At some point the compiler will search for the entity "lpm_sub", which you probably haven't created as you want to invoke an existing LPM function. Hence the error.
LPM_TYPE is to be seen as a constant rather than a parameter. LPM functions go back a long time, at some point it was an industry standard.
You could do it like this
library lpm ; use lpm.lpm_components.all ; - - - lpm_sub_component1 : lpm_add_sub generic map ( lpm_direction : STRING := "ADD"; . . . ) port map ( . . . ) ; lpm_sub_component2 : lpm_add_sub generic map ( lpm_direction : STRING := "SUB"; . . . ) port map ( . . . ) ;
That works, thanks!
even simpler, use behavioural VHDL:
c <= a + b;
f <= d - e;
etc.
--- Quote Start ---
c <= a + b;
f <= d - e;
etc.
--- Quote End ---
yes it is a lot less typing and I do it that way almost always, but that wasn't the question ... necsup was contemplating LPM-functionality in general
