FPGA Intellectual Property
6671 Discussions
Using registers to debug in SignalTap
I've been using this technique for several months, and I'm curious if anyone else does the same or if there is a better way.
When I want to track a signal in SignalTap, I do the following:
  1. Add a RegOut block to my model and give it a name like "DebugFIFODataOut".
  2. Generate DSP Builder, Qsys, and run Synthesis
  3. In SignalTap, search for *debugfifodataout* with filter set to Design Entry (all names).
  4. Drill down to the busSlaveFabric_*
  5. Insert the in_AMMregisterPortData* and in_AMMregisterPortWriteEn*
  6. Add meaningful Aliases to the signals
Note that you can use the write signal on the register as well as you are not actually concerned with register itself.
