FPGA Intellectual Property
6670 Discussions
Using signed binary fractional (SBF) in HIL
Hello!
In my hardwar-in-loop (HIL) design, I am trying to give input in signed binary fractional (SBF) format, which is one of the options ( also provided for IOs), available at function level. After putting the HIL block in the design and replacing all other functions, it again requires to specify some rules on I/Os. Here it only provides option for signed or unsigned.
I could not find any way to specify the bus type as SBF in the settings before configuring the device for my HIL. I think, as a result I can not get the proper result rather it turns to 0.
Please help me out!!!
Thanks very much!!!
Regards-
When you select each port in the HIL GUI, there should be < and > buttons to the right of the bit width which allow you to move the binary point.
Thank you sir... great!!!
dunno why couldn't recognize before....
once again thank you!!!
