FPGA Intellectual Property
6656 Discussions
V-Series Avalon-MM DMA Interface for PCIe Solutions
Hi to all,
I'm using the V-Series Avalon-MM DMA Interface for PCIe with an external descriptor.
In order to support multi-DMA channels, I implemented two DMA Multi-Channel Controller Example Design (see fig 1).
Unfortunately my architecture doesn't work properly. In fig.2 the bug (fig 3 and 4 for details) Fig 3: The first read (in orange) of 8 words @ 256bit ends. The second read (green) of 48 words @256bit is divided by the DMA Multi-Channel
Controller into 3 subdescriptors with a payload size of 16 words;
the processing READ A is completed. Fig.4
Four write-operation (white and yellow) end properly.
Finally the READ B (in red) of 48 words @256bit (generated by the same descriptor of READ A),
doesn't end... The problem does not occur in case of smaller READ A e B. Thanks Francesca
