FPGA Intellectual Property
6670 Discussions
[Video Sync Generator] Cannot send 24-bit RGB
Hello
I have a problem with generating data for an LCD.
I do have the 5MP camera from terasic, and that works fine. I can see the output on my VGA screen.
I have also a LCD screen. I want to use the [Video Sync Generator] (Pheripherals > Display) That module is created for LCD's with an Altera MAX chip. These chips works with 8 bit parallel (3 beats). But I don't have a LCD with these MAX chips, so I need the three 8-bit signals parallel, so 24 bits per clock tick.
That is supported by that module.
Now is the problem that I have the image resampled to 24bit (3x8), but that has to be merged together to just 24 bits, otherwise the module will not accept it.
I have already tryed to do that with Color Plane Sequencer, but without results.
Is there a solution? So is it possible to resample 24bit (3x8) to 24bit(1x24) ?
Hilco
The Netherlands (sorry for my bad English;))
i'm not sure you can do this with included Qsys components, you might have to write a simple custom component
Thanks for you're reply,
I solved the problem by using another controller, the VGA controller. There is also an option for LCD screens, and with a bit of editing the source code, it works with my screen.
