FPGA Intellectual Property
6670 Discussions
Wrong address range for custom IP in SOPC
Hello guys,
I would pls like a hint or a wise word on this funny issue that I have related to address ranges.
In detail, I have designed my own custom IP core that is a simple slave for the avalon bus. Its like an on-chip ram, but its not a RAM it has some other logic as well.
This IP core has an address port ADDRESS_PORT(8 DOWNTO 0). So that is 9 bits for addressing, in other words I want to address 512 words of RAM. The funny thing is that when I add my component on the SOPC builder along with a NIOS some RAM etc. and I do "auto assign base addresses" then the address range that is assigned for my component by SOPC is 12bits!
Just to make it more clear, for example if the base address for my component is 0x1000 then the range assigned by SOPC to the component is:
0x1000-0x1FFF! That is 12 bits right? I'm expecting something like that:
0x1000-0x11FF...so 9 bits=512words.
What seems to be wrong? Why the SOPC cannot understand the address range correctly since my address port is 9 bits?
Thank you for your help!!
Please show your code, it's difficult to guess where the problem comes from without it...
The answer to your problem lies in the interconnect fabric geberated by the SoPC builder. To quote form the Avlaon Spec (where it describes the address port of an Avalon Slave, Table 3.1):
"Specifies an offset into the slave address space. Each
slave address value selects a word of slave data. For
example, address= 0 selects the first <slave data width>
bits of slave data; address=1 selects the second <slave
data width> bits of slave data."
Therefore, in your Avalon Slave, your address port should contain enough bits to address all the words in your address space - irrespective of the width of the word. So if you have 512 8 bit words or 512 64 bit words, your address port will still be 9 bits.
When SoPC builds your system, it looks at the word width and the address width and then generates the required logic to connect to the Avalon bus master. The Avalon Bus master always addresses bytes. To qute from tabel 4.3 in the spec (The Master address port):
"The
address signal represents a byte address
regardless of the data-width of the master. The
value of the address must be aligned to the data
width. To write to specific bytes within a data word,
the master must use the byteenable signal.
Masters always issue byte addresses, regardless
of the data width of the master or slave port. The
system interconnect fabric translates this address
into a word address in the slave’s address space
so that each slave access is for a word of data from
the perspective of the slave.
So your 512 x 64 bit slave, will aways occupy 4096 bytes, or 12 bits, in the master address space. If the Avalon bus master is 32 bits wide (as is the case when using Nios), you will need to do two consecutive accesses to write to your slave. You may need to use the byteenable lines so that the interconnect fabric can show you when it is writing to the upper 32 bits and when it is writing to the lower 32 bits.
Also look at table 3.3 of the Avalon spec. for an example for a 32 bit master writing to a 64 bit slave.
Niki
hey sorry i couldnt reply earlier but thanks alot for the detailed reply.. niki.... i did end up getting it to work using flags and offsets.. :D
i am stuck at another place.. i know always stuck somewhere..
i want a piece of code to be repeated 32 times.. i obviously cant use while or for in verilog..
i have written the following for the whole process to repeat..
///////////////////// code /////////////////////////////
always @ (posedge CLOCK_50)
begin
if(bit_1 < 32 && bit_1 >= 0)
begin
count_di <= 1;
end
else
begin
count_di <= 0;
end
end // of always.. for count
//// the above part is for performing the while operation ////
/////////// main code////////////
always @ (posedge CLOCK_50) // each 20nsec
begin
if(ready_di ==1 )
begin
bit_1 = 6'd32;
la = 0;
la_temp = 0;
ty_c = {32'd0,py1};//ty};
tx_c = {1'b0,px1,31'd0};
end
if ( count_di != 0 )
begin
diff = ty_c - tx_c;
la_temp = la_temp << 1;
if( !diff[63] )
begin
ty_c = diff;
la_temp[0] = 1'd1;
end
la = la_temp;
tx_c = tx_c >> 1;
bit_1 = bit_1 - 1'b1;
end
if(bit_1 == 0 && la >0)
begin
temp3= (la*la);
temp4 = px1-qx1;
qx1 = temp3 - temp4;
end
//////////////////// end of code/////////////////////////
the above is the not the entire code just a subset of it ..
my problem / doubt..
the above piece of code works fine and i am getting the output correct too.. but it doesnt happen all at once..
I mean when the configure thew FPGA and run Nios II.. I actually have to run Nios II 32 times to see the output..which is obviously not right.
i want the whole loop to be done at once i hope u all understand what i m trying to say..
Please do help me out here..
Thanks again.
you all are very helpful..
Hi clggrad,
You probably have already found a solution. I am not that familiar with Verilog, but what I can gather from your code is that you want a fair amount of processing to happen instantaniously and that each iteration depends on the results from the previous iteration. Although it may be possible to describe this as a huge blob of logic, it would probably not be very practical. A registered processing loop as you have implemented is a better approach since it allows you to re-use the resources. You can optimize the performance by unrolling the loop slightly (say 2 or 4 time). This way you will get an answer after 16 or 8 clock cycles.
Niki
