FPGA Intellectual Property
6670 Discussions
altera_mem_if_ddr3_emif
NGord
Hi
altera_mem_if_ddr3_emif used to have a parameter box 'enable afi half rate clock' in Quartus 18
Somewhere between V18 and V23 it has disappeared and I cant get afi_half_clk to work any more.
How do I enable afi_half_clk in V23?
AdzimZM_Intel
Hi @NGord
Do you have any further question in this thread?
Adzim
NGord
If opening Platform designer with no Project selected , I see the 'half-rate' tick box in DDR3 SDRAM Controller with UniPHY Intel FPGA IP, regardless of Quartus version.
If the  project is for a MAX10, the tick box disappears and I have no afi_half_clk.
I can find no explanation for this.
NGord
Is the issue that the MAX10 PLL doesnt have enough PLL outputs?
AdzimZM_Intel
Hi NGord,
For Max 10 FPGA device, the DDR3 EMIF IP doesn't support afi half rate clk.
I think the Cyclone V device is used by default if no project is opened.
Therefore, the DDR3 EMIF IP is targeting to Cyclone V and you may see the afi half rate clock option.
Adzim
AdzimZM_Intel
Hi @NGord
Adzim
