FPGA Intellectual Property
6673 Discussions
altsyncram simulation - X output?
I'm trying to simulate a dual-port block ram using altsyncram, but the output(q_a, q_b) of the block ram is X when initialized. According to manual it should be set to zero. I don't understand why this is happening - any suggestion will be appreciated.
Following is the way I instantiate it:
library ieee; use ieee.std_logic_1164.all; library altera_mf; use altera_mf.all; entity mem_2p_m9k is generic( addr_width : integer := 12; num_words : integer := 4096; data_width : integer := 16 ); port( clk : in std_logic; addr_a : in std_logic_vector(addr_width-1 downto 0); addr_b : in std_logic_vector(addr_width-1 downto 0); datain_a : in std_logic_vector(data_width-1 downto 0); datain_b : in std_logic_vector(data_width-1 downto 0); wren_a : in std_logic; wren_b : in std_logic; q_a : out std_logic_vector(data_width-1 downto 0); q_b : out std_logic_vector(data_width-1 downto 0) ); end mem_2p_m9k; architecture arch of mem_2p_m9k is component altsyncram GENERIC ( address_reg_b : STRING; clock_enable_input_a : STRING; clock_enable_input_b : STRING; clock_enable_output_a : STRING; clock_enable_output_b : STRING; indata_reg_b : STRING; intended_device_family : STRING; lpm_type : STRING; numwords_a : NATURAL; numwords_b : NATURAL; operation_mode : STRING; outdata_aclr_a : STRING; outdata_aclr_b : STRING; outdata_reg_a : STRING; outdata_reg_b : STRING; power_up_uninitialized : STRING; ram_block_type : STRING; read_during_write_mode_mixed_ports : STRING; read_during_write_mode_port_a : STRING; read_during_write_mode_port_b : STRING; widthad_a : NATURAL; widthad_b : NATURAL; width_a : NATURAL; width_b : NATURAL; width_byteena_a : NATURAL; width_byteena_b : NATURAL; wrcontrol_wraddress_reg_b : STRING ); PORT ( wren_a : IN STD_LOGIC ; clock0 : IN STD_LOGIC ; wren_b : IN STD_LOGIC ; address_a : IN STD_LOGIC_VECTOR (11 DOWNTO 0); address_b : IN STD_LOGIC_VECTOR (11 DOWNTO 0); q_a : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); q_b : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); data_a : IN STD_LOGIC_VECTOR (15 DOWNTO 0); data_b : IN STD_LOGIC_VECTOR (15 DOWNTO 0) ); END COMPONENT; begin mem_inst: altsyncram generic map( address_reg_b => "CLOCK0", clock_enable_input_a => "BYPASS", clock_enable_input_b => "BYPASS", clock_enable_output_a => "BYPASS", clock_enable_output_b => "BYPASS", indata_reg_b => "CLOCK0", intended_device_family => "Stratix III", lpm_type => "altsyncram", numwords_a => num_words, numwords_b => num_words, operation_mode => "BIDIR_DUAL_PORT", outdata_aclr_a => "NONE", outdata_aclr_b => "NONE", outdata_reg_a => "NONE", outdata_reg_b => "NONE", power_up_uninitialized => "FALSE", ram_block_type => "M9K", read_during_write_mode_mixed_ports => "DONT_CARE", read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ", read_during_write_mode_port_b => "NEW_DATA_NO_NBE_READ", widthad_a => addr_width, widthad_b => addr_width, width_a => data_width, width_b => data_width, width_byteena_a => 1, width_byteena_b => 1, wrcontrol_wraddress_reg_b => "CLOCK0" ) port map( wren_a => wren_a, clock0 => clk, wren_b => wren_b, address_a => addr_a, address_b => addr_b, q_a => q_a, q_b => q_b, data_a => datain_a, data_b => datain_b ); end arch;
Either altera is not right or the simulator. If you have to initialise then use a mif or hex set to zeros.
Problem solved. I think it's due to my bad of wrapping another layer around generated core.
