FPGA Intellectual Property
audio core
I am using audio core to generate digital audio filters . I want to pass digital signal from ADC to DAC , but it can't operate . Who can help me this problem . Thank you very much !!!
here is my code by C
while(1)
//wait for interrupt signal
ctrl_reg = IORD_ALT_UP_AUDIO_CONTROL(ALT_UP_AUDIO_BASE);
ctrl_reg &= ALT_UP_AUDIO_CONTROL_RI_MSK;
if(ctrl_reg == 0) continue; //if there isn't read interrupt signal , continue wait
//clear interrupt flag
ctrl_reg &= ~ALT_UP_AUDIO_CONTROL_RI_MSK;
IOWR_ALT_UP_AUDIO_CONTROL(ALT_UP_AUDIO_BASE, ctrl_reg);
//read left channel
alt_up_audio_read_left_channel(&left_reg,read_length);
//read right channel
alt_up_audio_read_right_channel(&right_reg,read_length);
// write left channel
alt_up_audio_write_left_channel(&left_reg,write_length);
// write right channel
alt_up_audio_write_right_channel(&right_reg,write_length);
Try this example, let me know if it works.
# include "alt_up_audio.h"
// assumes input only from right channel
int main()
unsigned sample_count;
long audiobuf[128];
alt_up_audio_reset_audio_core(); //get the audio started
while (1)
sample_count = alt_up_audio_read_right_channel(audiobuf,128);
if(sample_count)
{ //must write both output channels
alt_up_audio_write_left_channel(audiobuf,sample_count);
alt_up_audio_write_right_channel(audiobuf,sample_count);
Hello, i am having the same problem , so is there any workaround for this?
Thanks!
