FPGA Intellectual Property
6671 Discussions
custom component with DCFIFO
Dear nios user!
I had associated a custom component(with DCFIFO) to Nios2 system. I used avalon MM slave interface and conduit interface.
My custom component is
module fifo_in (
// Avalon clock interface siganals
input csi_clockreset_clk,
input csi_clockreset_reset_n,
// Signals for Avalon-MM slave port
input avs_s1_address,
input avs_s1_chipselect,
input avs_s1_read,
output [31:0] avs_s1_readdata,
input avs_s1_write,
input [31:0] avs_s1_writedata,
// Signals export to top module
input avs_s1_export_clk,
input avs_s1_export_req,
input [31:0] avs_s1_export_capture_readdata
fifo_32 u1(
//read side
.q(avs_s1_readdata),
.rdclk(~csi_clockreset_clk),
.rdreq(avs_s1_read),
//write side
.data(avs_s1_writedata),
.wrclk(~csi_clockreset_clk),
.wrreq(avs_s1_write)
endmodule
My Source Code is
for(i=0; i<0x10; i++)
IOWR(FIFO_IN_0_BASE, 0, i);
printf("0x%08x ", IORD(FIFO_IN_0_BASE, 0));
This is FIFO read and write is OK.
But, my custom component is modified. Modified custom component is
module fifo_in (
input avs_s1_read,
input avs_s1_write,
fifo_32 u1(
//read side
//write side
.data(avs_s1_export_capture_readdata),
.wrclk(avs_s1_export_clk),
.wrreq(avs_s1_export_req)
endmodule
Modified custom component's read value is
0x00000000
0x00000000
0x00000000
0x00000000
Please help me. Thank you.
I have tested input data that is camera signal.
avs_s1_export_capture_readdata is camera's image data.
avs_s1_export_clk is camera's PIXCLK.
avs_s1_export_req is camera's HSYNC and VSYNC.
I get exactly above signal(camera image data, PIXCLK, HSYNC, VSYNC).
What is wrong?
Please help me...
