FPGA Intellectual Property
6360 Discussions
do the LPM_SHIFTREG must be used in the spi serial receiving code when the clock fequency is too fast?
zlan01
input       spi_data_i;
output reg   spi_data_o;
reg [15:0]shift_sender;
reg [15:0]shift_receiver;
code 1: spi receiving code=========================================================
always @(posedge spi_clk_50M or negedge spi_rst_n)
begin
   if(~spi_rst_n)
         shift_receiver   <= 16'h0;
   else
           shift_receiver   <= {shift_receiver[14:0],spi_data_i};
end
code2 :spi sending code ============================================================
begin
   if(~spi_rst_n)
      begin
         shift_sender   <= 16'h0;
         spi_data_o         <= 1'b0;
      end
   else
      begin
         spi_data_o <= shift_sender[15];
         shift_sender  <= {shift_sender[14:0],1'b0};
      end
end
I am implemented a spi interface which clock is 50Mhz shown above, the sending code work correctly,but the receiving code can not receive any data using verilog to implement the shifting in register?
I have implemented a uart interface which clock fequency is 1Mhz using the simliar code above,the receiver and sender all work correctly;
do the LPM_SHIFTREG must be used in the serical receiving code when the clock fequency is too fast such as 50Mhz?why ?
KhaiChein_Y_Intel
May I know which device you are using? It is mentioned that the receiving code cannot receive any data using Verilog to implement the shifting in register? Could you explain in details and provide error message (if any). Do you check the simulation result and sdc constraints?
KhaiChein_Y_Intel
May I know if you have any updates?
