FPGA Intellectual Property
6671 Discussions
frame reader configuration and initialization
I use the frame reader in my design with the following settings:
Bits per pixel per color plane: 8
Number of color planes in parallel: 3
Number of color planes in sequence: 1
Maximum Image width: 1920
Maximum Image height: 1080
Master port width: 64
Read master FIFO depth: 1024
Read master FIFO burst target: 64
Use separate clock for the Avalon MM master interface: unchecked
Kindly confirm if the following calculations for number the words and the Single Cycle Color Patterns are true or not
1- // Words
IOWR(FRAMEREADER_BASE, 5, 259200); // (1920*1080*8*3)/48= 1036800
2- // Single Cycle Color Patterns
IOWR(FRAMEREADER_BASE, 6, 2073600); // 1920*1080=2073600 number of pixels in the frame multiplied by the number of single cycles required to represent one pixel
Your reply will be highly appreciated
Why did you divide by 48?
The frame reader will only transfer whole "single cycle color patterns" (pixels). With a 64-bit master port width and 24-bit pixels, the Frame Reader will only be transferring 48 bits (not 64 bits) of picture data at a time.
