FPGA Intellectual Property
6669 Discussions
help needed : upscaling video
I am using altera VIP suit , ver 8.0 and Quartus II ver 8.0. And using 3c120 development board.
In the current design, i need to upscale the video from 720x576 PAL to minimum 800x600 ... However, the quality of the upscaled image is not very good and video looks pixelated.
In the scaler, I am using polyphase algorithm with Lancoze 2 coefficients.
I tried increasing number of filter taps upto 12 for both vertical and hosrizontal filters in scaler. Also changed the coefficients from lancoze 2 to lancoze 3 ..
I tried to set the resolution to 800x640 so as to maintain the H/W ratio.
But the still the video quality is same.
Any pointers, how to decide the number of filter taps required and the coefficients ? Do I need to manually provide coefficients for upscaling or one of the given lancoze coefficients would do.
Thanks in advance.
Foram
Quoting the VIP user guide, scaling up with any input/output resolution:
4 taps, 16 phase
Precision: Signed, 1 integer bit, 7 fraction bits
Coefs: Lanczos-2, or Bicubic
I believe you should stick to these recommendations. In practice it usually looks worse when using more than 4 taps for upscaling.
I assume you are using the motion-adaptive deinterlacer before the scaler. If not and if the quality is not as good as expected you should probably start from there.
Kind regards,
vgs
For upscaling video, you don't want a big filter, I would instead use the scaler in either bicubic or even bilinear mode. Try bilinear mode first.
Jake
Thanks Vgs and Jake.
I am using motion adaptive deinterlacer. and I also used the scaler setting mentioned by Vgs before trying the 12 tap filter.
However, I have not tried with bicubic or bilinear mode. Will try using this mode first.
Thanks a lot.
