- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i am trying to run the LL 10G MAC examples, i found one at https://fpgawiki.intel.com/wiki/Low_Latency_Ethernet_10G_MAC_using_Arria_10_PHY_10GBASE-R_Register_Mode and there is one provided with the Quartus software.
For both examples, when comping the avalon_driver.sv component, I get errors as described below: (snippet 1), for the fpgawiki example
or for the Quartus provide example see snippet 2
# SILENCE -- Set to true to suppress all informational and/or warning messages in the generated simulation script.
# FORCE_MODELSIM_AE_SELECTION -- Set to true to force to select Modelsim AE always.
# [exec] dev_com
# Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017
# Start time: 12:39:20 on Jun 27,2019
# vlog -reportprogress 300 C:/intelFPGA/18.0/quartus/eda/sim_lib/altera_primitives.v -work altera_ver
# ** Error: (vlog-7) Failed to open design unit file "C:/intelFPGA/18.0/quartus/eda/sim_lib/altera_primitives.v" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 12:39:21 on Jun 27,2019, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
# ** Error: C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./tb_run.tcl line 29
# C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
# while executing
# "vlog C:/intelFPGA/18.0/quartus/eda/sim_lib/altera_primitives.v -work altera_ver"
# ("eval" body line 1)
# invoked from within
# "eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/altera_primitives.v" ..."
# "if [string is false -strict [modelsim_ae_select $FORCE_MODELSIM_AE_SELECTION]] {
# eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_CO..."
# ("eval" body line 5)
# "dev_com "
# -- Compiling module altera_eth_top
# -- Compiling package avalon_if_params_pkt
# -- Compiling module avalon_bfm_wrapper
# -- Importing package avalon_if_params_pkt
# ** Warning: ** while parsing file included at ../avalon_driver.sv(4)
# ** at avalon_if_params_pkg.sv(5): (vlog-2275) 'avalon_if_params_pkt' already exists and will be overwritten.
# ** Warning: ** while parsing file included at ../avalon_driver.sv(5)
# ** at avalon_bfm_wrapper.sv(9): (vlog-2275) 'avalon_bfm_wrapper' already exists and will be overwritten.
# ** Error: ../avalon_driver.sv(50): (vlog-13006) Could not find the package (eth_register_map_params_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
# ** Warning: ../avalon_if_params_pkg.sv(5): (vlog-2275) 'avalon_if_params_pkt' already exists and will be overwritten.
# ** Error: ../eth_mac_frame.sv(5): Typedef 'eth_mac_frame' multiply defined.
# ** Error: ** while parsing file included at ../tb.sv(5)
# ** while parsing file included at avalon_driver.sv(6)
# ** at eth_mac_frame.sv(5): Typedef 'eth_mac_frame' multiply defined.
# End time: 12:26:47 on Jun 27,2019, Elapsed time: 0:00:00
# Errors: 3, Warnings: 3
# Error in macro ./tb_run.tcl line 50
# while executing
# "vlog -work work ../*.*v"
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi AndyN,
Thanks, i am using the starter edition. ModelSim - Intel FPGA Edition vcom 10.6c Compiler 2017.07 Jul 26 2017.
i also submitted this issue on Forum.Intel, a little bit different, and looking again at transcript, i am not so sure if it is dev_com, see the snippet below.
vlog-13006) Could not find the package (avalon_mm_pkg). See line 32, 33 in Transcript Code generated by modelsim.
Where can i find this avalon_mm_pkg.sv code, and where should i put it?
i built a PHY for the cyclone10GX. I now want to connect the LL 10G MAC to it, and as test now trying to run the alt_em_10g32_EXAMPLE_DESIGN generated by QUARTUS version 18.0.0 build 219 04/24/2018 SJ Pro Edition with Cyclone10GX libraries. Modelsim version starter edition 10.6C, revision 2017.07.
I managed to get the msim_setup.tcl script running, until i face the following issue : when it compiles avalon_driver.sv, in line 66 it wants to import avalon_mm_pkg, but this file does not exist.
Modelsim reports (after compiling a lot of cyclone stuff) : see snippet, where in line 15 [exec] dev_com stops, and [exec] com starts
# Top level modules:
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:08
# Errors: 0, Warnings: 584
# Start time: 18:02:38 on Jun 25,2019
# vlog -reportprogress 300 C:/intelfpga_pro/18.0/quartus/eda/sim_lib/cyclone10gx_hip_atoms.v -work cyclone10gx_hip_ver
# -- Compiling module cyclone10gx_hssi_gen3_x8_pcie_hip
# -- Compiling module twentynm_hssi_gen3_x8_pcie_hip
# cyclone10gx_hssi_gen3_x8_pcie_hip
# twentynm_hssi_gen3_x8_pcie_hip
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# [exec] com
# vlog -reportprogress 300 -sv ../../../rtl/phy/altera_eth_10gbaser_phyaltera_xcvr_native_a10_180/sim/altera_xcvr_native_a10_functions_h.sv -work altera_common_sv_packages
# -- Compiling package altera_xcvr_native_a10_functions_h
# --none--
# vlog -reportprogress 300 -sv "+incdir+../models" ../models/tb_top.sv
# -- Compiling package eth_register_map_params_pkg
# ** Error: ** while parsing file included at ../models/tb_top.sv(19)
# ** at ../models/avalon_driver.sv(66): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
# End time: 18:02:39 on Jun 25,2019, Elapsed time: 0:00:01
# Error in macro ./mentor.do line 25
# while executing
# "vlog -sv {+incdir+../models} "../models/tb_top.sv" "
# "eval $file"
# ("foreach" body line 2)
# "foreach file $design_files {
# eval $file
# ("eval" body line 13)
# "com"
What is your advice? regards, Pieter
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Pieter,
Please refer similar case which describes the solution.
https://forums.intel.com/s/question/0D70P000005tbf1SAA/how-to-use-avalonmm-master-bfm
Anand
