FPGA Intellectual Property
6670 Discussions
master other than NIOS cpu
hi all,
I am using Quartus SOPC builder to make a system. But I am using my microcontroller(8051) as cpu. For that if i connect a single slave, it is working fine but if connect more than one, none of them work. What may be the problem?
Thank you.
it's a good question, I'm guess this room almost amateurs so they can't answer you :) !!!
1 - Are you obeying the waitrequest rule?
2 - Is your address map correct?
What is the failure mode? In what way is it "not working"?
Jake
