@JohnT_Intel
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/hw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/sw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/hw_builtin.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/sw_builtin.iipx
Hi Ashwi,
More information needed here on how did you encounter such error?
Hi @SyafieqS
when i will try generate ip/ try to open the platform designer that time error will come
Hi Ashwi,
Verify the .ipx file is there in the directory and try to check you environment variable if they are added for both quartus and nios2eds.
@SyafieqS @Deshi_Intel @JohnT_Intel
I checked in folder .ipx is found, enviranomnet also path added but again we are facing same issue. can you please address this issue
May I ask if this problem has been resolved for you? I encountered the same issue while working with Platform Designer.
