FPGA Intellectual Property
6673 Discussions
onchip RAM resource usage
Hi all
I'm using a cyclone III EP3C40 device which boasts 126 M9K blocks for over 1Mbit onchip RAM.
I understand that 'real' memory bits are 8/9, so I have almost exactly 1Mbit.
My former design used 618472 memory bits and fitter report correctly shows 53% RAM is used.
So I increased the onchip RAM used in sopc builder, 8kbytes more: it should still fit in my device.
But Quartus answer is not!
When Quartus processes the design, it tells me it can't fit in the device because I'm using 102% of available memory.
Why?
It depends how effeciently you are using the memory. each M9k holds 9kbits, and can only be used by 1 thing. If you have something in the design somewhere that doesnt use the memories to their max potential (like I suspenct you have) then you run into the situation you have.
Thank you for your answer, Tricky
You are right. I explored the fitter report and found out:
Total memory bits: 618472 ot 1161216 (53%)
M9Ks: 122 of 127 (97%)
These are the ip modules using M9Ks in my design:
- Nios II/f with cache
- clock crossing bridge
- 4 onchip memory
- 2 tse mac
- 2 sgdma
- epcs and jtag controllers
If I understand correctly what you said, even if Quartus reports a device utilizing only 40 memory bits, actually it requires a whole M9K block, then 8kbits !
I discovered tse and sgdma modules contain plenty of such devices.
Can I overcome this situation?
I believe I once saw somewhere an option forcing synthesis of memory into registers rather than M9K but now I can't find it any more. Is this possible and safe?
Thank you
Cris
