FPGA Intellectual Property
6670 Discussions
problem with DDR2 SDRAM controller
hello
i have a little problem with the DDR2 SDRAM high performance controler that i create using Mega Wizard application.
i have created it and it was successfully compiled in Quartus (8.1 if thats matters) and simulated by the Quartus program (with modelsim 6.3).
then i wrote a little wrapper entity to match the example design to my needs and it also successfully compiled and simulated by the Quartus.
but i noticed something weird : when i compile the files manually and simulate them (using standart vhdl 93 compiler and modelsim 6.3) i notice a weird warnings - some signals may have multiple drivers.
the problem is that the warning refer to a file that the Mega Wizard generated and i didnt touch it.
the problematic file is <my design name>_phy_alt_mem_phy_seq.vhd
the problematic signals are: mmi_ctrl, parameterisation_rec and mmi_pll.
by the way the simulation is running fine although the warnings...
my questions are:
1) are those warning important? the simulation is running fine.
2) how do i fix those warnings (even if they are not important they are still annoying and can mask more critical warnings)
thank you for reading and answering
Can you provide us with the explicit printout from ModelSim?
Jake
i dont really sure which printout you need so i hope you want those:
warnings when compiling the libraries:
** Warning: /<path for altera>/altera/quartus2/9.0/quartus/eda/sim_lib/stratixiv_atoms.vhd(1852): VITAL timing generic missing port reference(s). (1076.4 section 4.3.2.1.2)
i dont really why there is a warning here because i didnt touch that file...
warnings when compiling the files:
i'm using liunx this command in linux environment :
vcom -O4 -work modelsim_work -93 -quiet -nologo -explicit -source <mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd
(all the other files necessary have been compiled without warnings)
the warnings for this file are:
# ##### /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12028): signal mmi_ctrl : t_mmi_ctrl; ** Warning: ../vhdl/vendors_ips/mega_wizard/<device name>/<device name>_phy_alt_mem_phy_seq.vhd(12028): Nonresolved signal 'mmi_ctrl' may have multiple sources. Drivers: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12306):Statement mmi /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12455):Process line__12455 Driven at: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12462) # ##### /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12064): signal parameterisation_rec : t_algm_paramaterisation; ** Warning: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12064): Nonresolved signal 'parameterisation_rec' may have multiple sources. Drivers: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12306):Statement mmi /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12455):Process line__12455 Driven at: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12460)# ##### /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12077): signal mmi_pll : t_mmi_pll_reconfig; ** Warning: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12077): Nonresolved signal 'mmi_pll' may have multiple sources. Drivers: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12306):Statement mmi /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12455):Process line__12455 Driven at: /<mega wizard path>/<device name>_phy_alt_mem_phy_seq.vhd(12461)
here are printout from modelsim transcript:
those warnings is showen only when i run the simulation, there are no warnings when i load the simulation
** Warning: Warning: Value for read_during_write_mode_mixed_ports is not honoured in DUAL_PORT operation mode when output registers are not clocked by clock0 for ram_block_type LUTRAM# Time: 0 ps Iteration: 0 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_read_dp_group_fr_rdp_rdp_per_group_1_rdp_altsyncram_ram_6752# ** Warning: Warning: Value for read_during_write_mode_mixed_ports is not honoured in DUAL_PORT operation mode when output registers are not clocked by clock0 for ram_block_type LUTRAM# Time: 0 ps Iteration: 0 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_read_dp_group_fr_rdp_rdp_per_group_0_rdp_altsyncram_ram_6829# ** Warning: Warning: Value for read_during_write_mode_mixed_ports is not honoured in DUAL_PORT operation mode when output registers are not clocked by clock0 for ram_block_type LUTRAM# Time: 0 ps Iteration: 0 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_postamble_fr_poa_gen_poa_group_1_poa_altsyncram_altsyncram_component_6085# ** Warning: Warning: Value for read_during_write_mode_mixed_ports is not honoured in DUAL_PORT operation mode when output registers are not clocked by clock0 for ram_block_type LUTRAM# Time: 0 ps Iteration: 0 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_postamble_fr_poa_gen_poa_group_0_poa_altsyncram_altsyncram_component_6102# ** Note: Stratix IV PLL was reset# Time: 0 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_clk_reset_clk_<device name>_phy_alt_mem_phy_pll_full_rate1_pll_5977/altpll_component/stratixiii_altpll/m4# ** Warning: Illegal value detected on input clock.# Time: 100 ns Iteration: 13 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_clk_reset_clk_stratixiii_dll_dll_5708# ** Note: Stratix IV PLL locked to incoming clock# Time: 118784 ps Iteration: 0 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_clk_reset_clk_<device name>_phy_alt_mem_phy_pll_full_rate1_pll_5977/altpll_component/stratixiii_altpll/m4# ** Note: # Time: 131288 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/reporting# ** Note: DLL to lock to incoming clock# Time: 2786304 ps Iteration: 9 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_clk_reset_clk_stratixiii_dll_dll_5708# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : gathered resync phase samples (for mtp alignment 0) is DGRB_PHASE_SAMPLES: 00000000111111111111111111111111111111111111111100000000000000000000000000000000# Time: 109778864 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/rsc_block# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : gathered resync phase samples (for mtp alignment 1) is DGRB_PHASE_SAMPLES: 00000000000000000000000000000000000000000000000000000000000000000000000000000000# Time: 208693840 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/rsc_block# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : gathered resync phase samples DGRB_PHASE_SAMPLES: 00000000111111111111111111111111111111111111111100000000000000000000000000000000# Time: 304807920 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/rsc_block# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : data-valid window found successfully.# Time: 305287240 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/rsc_block# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : gathered mimic phase samples DGRB_MIMIC_SAMPLES: 1111111111111111111111111111111111111111# Time: 341911456 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/trk_block# ** Note: <device name>_phy_alt_mem_phy_seq (dgrb) : mimic window successfully found.# Time: 342094848 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/dgrb/trk_block# ** Warning: <device name>_phy_alt_mem_phy_seq (admin) : mode register and generic conflict:# * generic MEM_IF_DQSN_EN is set to 'disable' DQSN# * user mode register MEM_IF_MR1 bit 10 is set to 'enable' DQSN# Time: 342615848 ps Iteration: 8 Instance: /<device name>_tb/ddr2_if_1/u_<device name>/<device name>_controller_phy_inst/<device name>_phy_inst/<device name>_phy_<device name>_phy_alt_mem_phy_<device name>_phy_alt_mem_phy_inst_<device name>_phy_alt_mem_phy_seq_wrapper_seq_wrapper_6153/<device name>_phy_alt_mem_phy_seq_wrapper_<device name>_phy_alt_mem_phy_seq_seq_inst_1453/admin# ** Note: <device name>_phy_alt_mem_phy_seq (top) : report...# -----------------------------------------------------------------------# -- **** ALTMEMPHY CALIBRATION has completed ****# -- Status:# -- calibration has : PASSED# -- PHY read latency (ctl_rlat) is : 16# -- address/command to PHY write latency (ctl_wlat) is : 4# -- read resynch phase calibration report:# -- calibrated centre of data valid window phase : 51# -- calibrated centre of data valid window size : 40# -----------------------------------------------------------------------
i'm sorry for the double post but the original message was too long
thank you for answering
hi deadalus,
i read your question about 'problem with ddr2 sdram controller', but i don't find a response.
please, if you find a solution for this problem, can you tell me? because i am in the same problem.
good work.
