FPGA Intellectual Property
6670 Discussions
problems with the sdram_input_efifo_module
sdram_input_efifo_module is one module from the SDRAM IP core(sdram.v) which offerred by ALTERA.I cannot understand how this module works,can someone gives me a explanation?
following the program
module sdram_input_efifo_module (
// inputs:
clk,
rd,
reset_n,
wr,
wr_data,
// outputs:
almost_empty,
almost_full,
empty,
full,
rd_data
output almost_empty;
output almost_full;
output empty;
output full;
output [ 43: 0] rd_data;
input clk;
input rd;
input reset_n;
input wr;
input [ 43: 0] wr_data;
wire almost_empty;
wire almost_full;
wire empty;
reg [ 1: 0] entries;
reg [ 43: 0] entry_0;
reg [ 43: 0] entry_1;
wire full;
reg rd_address;
reg [ 43: 0] rd_data;
wire [ 1: 0] rdwr;
reg wr_address;
assign rdwr = {rd, wr};
assign full = entries == 2;
assign almost_full = entries >= 1;
assign empty = entries == 0;
assign almost_empty = entries <= 1;
always @(entry_0 or entry_1 or rd_address)
begin
case (rd_address) // synthesis parallel_case full_case
1'd0: begin
rd_data = entry_0;
end // 1'd0
1'd1: begin
rd_data = entry_1;
end // 1'd1
default: begin
end // default
endcase // rd_address
end
always @(posedge clk or negedge reset_n)
begin
if (reset_n == 0)
begin
wr_address <= 0;
rd_address <= 0;
entries <= 0;
end
else
case (rdwr) // synthesis parallel_case full_case
2'd1: begin
// Write data
if (!full)
begin
entries <= entries + 1;
wr_address <= (wr_address == 1) ? 0 : (wr_address + 1);
end
end // 2'd1
2'd2: begin
// Read data
if (!empty)
begin
entries <= entries - 1;
rd_address <= (rd_address == 1) ? 0 : (rd_address + 1);
end
end // 2'd2
2'd3: begin
end // 2'd3
default: begin
end // default
endcase // rdwr
end
always @(posedge clk)
begin
//Write data
if (wr & !full)
case (wr_address) // synthesis parallel_case full_case
1'd0: begin
entry_0 <= wr_data;
end // 1'd0
1'd1: begin
entry_1 <= wr_data;
end // 1'd1
default: begin
end // default
endcase // wr_address
end
endmodule
