FPGA Intellectual Property
6673 Discussions
tripple speed ethernet system side connections the FPGA HPS processor
FFAA
how do i connect the and handle (the streaming )
the system side to an HPS in an FPGA design..
The current design has the Avalon MM interface connection but not streaming connections.
How do the HPS perform a Transmit/Receive request  to the IP core.
Jeet14
Please do allow sometime to check if there is any reference design with Avalon Streaming Interface (HPS+TSE). I will update you soon.
Tiwari
Jeet14
We have TSE design with the HPS on the A10 SoC. In this TSE is configured as Avalon memory map interface.
https://www.rocketboards.org/foswiki/Documentation/A10TSEReferenceDesignLTS
For TSE configuration as Avalon streaming interface, you can refer the below link which is with NIOS II/V.
https://www.intel.com/content/www/us/en/design-example/714912/intel-arria-10-fpga-nios-ii-processor-simple-socket-server-design-example.html
https://www.intel.com/content/www/us/en/design-example/763968/arria-10-fpga-simple-socket-server-for-the-nios-v-m-processor-design-example.html
You can take above as reference while working HPS.
Tiwari
Jeet14
Hi
Please let me know if there is any query on this.
Tiwari
Jeet14
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
