FPGA Intellectual Property
6673 Discussions
what is debug_mem_slave interface of Nios II Processor
VVavr1
I have noticed debug_mem_slave Avalon-MM slave interface in Nios II Processor IP core but I am not able to find any documentation what it does?
I assumed it is some kind of on-chip ram embedded in Nios II but I am not able to generate BSP without on-chip ram.
SEVERE: CPU "nios2_gen2_0" has no memories connected to its Avalon master(s)
So it seems that debug_mem_slave is not substitute for on-chip ram.
Ahmed_H_Intel1
Hi, This is useful in debugging, please read "Nios II Gen 2 Processor Reference Guide"> Break Exceptions https://www.intel.com/content/www/us/en/programmable/documentation/iga1420498949526.html#iga1409335503563 For example, if you want to set the break point when Debugging Nios II, but at this time you can not get the values of various registers from JTAG unless you skip the instruction to another memory. For this reason, it is necessary to skip to separate memory at Break, and it is automatically set to debug_mem_slave when using JTAG debug module. Embedded_guy
