FPGA Intellectual Property
6670 Discussions
where to find testbench with Scalable Switch Intel® FPGA IP for PCI Express?
wilson1977
After generate a R-tile scalable switch ip example for AGIB027R29A1E2VR3  with quartus25.1 ,there is no testbench.
how to do simuation?
Wincent_Altera
Which simulator that you try to use ?
You may find the simulation folder under ../xxx../switchIP/intel_pcie_sep_rtile_top_0_example_design/switch_ed/sim/
Please ensure that you enable the simulation tab upon design example generation
Let me know if you still unable to find it.
Wincent_Altera
wilson1977
There is only a sim top file under switch_ed/sim directory,no testbench file.
can you snapshot?
Wincent_Altera
Hi Wilson,
If you are refer to the xxx_tb.v file you can refer to switch_ed.v
Let me know if I am not answering your question or I miss-understand anything.
Wincent_Altera
wilson1977
There are two demux_1stage_pipeline code under switch_user_logic/demux.v .The upper parts are commented.The lower parts are opened.
I want to use the  upper parts code(commented). can it work?
// | single buffered pipeline stage
//module demux_1stage_pipeline
// #( parameter PAYLOAD_WIDTH = 8 )
// ( input clk,
// input reset_n,
// output reg in_ready,
// input in_valid,
// input [PAYLOAD_WIDTH-1:0] in_payload,
// input out_ready,
// output reg out_valid,
// output reg [PAYLOAD_WIDTH-1:0] out_payload
// reg in_ready1;
// always @* begin
// in_ready = out_ready || ~out_valid;
// // in_ready = in_ready1;
// // if (!out_ready)
// // in_ready = 0;
// end
// always @ (posedge clk) begin
// if (!reset_n) begin
// in_ready1 <= 0;
// out_valid <= 0;
// out_payload <= 0;
// end else begin
// in_ready1 <= out_ready || !out_valid;
// if (in_valid) begin
// out_valid <= 1;
// end else if (out_ready) begin
// out_valid <= 0;
// end
// if(in_valid && in_ready) begin
// out_payload <= in_payload;
// end
// end // else: !if(!reset_n)
// end // always @ (negedge reset_n, posedge clk)
//endmodule //
( input clk,
input reset_n,
input in_valid,
input out_ready,
always @ (posedge clk or negedge reset_n)
begin
if (!reset_n)
begin
out_valid <= 0;
out_payload <= 0;
in_ready <= 0;
end
else
begin
in_ready <= out_ready;
out_valid <= in_valid;
end
end
endmodule//
Wincent_Altera
Hi Wilson,
Is there any special reason you need to used the commended part ?
Just try to understand more and check if the application is ideal or not.
>> Well,  as I go through the code, the (commented) code seen to be likely more robust in handling backpressure and ensuring data integrity in a pipeline scenario.
>> Meanwhile for the (uncommented) code simplifies the logic by directly mapping input signals to output signals
>> Answering your question, yes you can - depends on your application and needs. As long as the compilation PASS , it shall be no problem.
WIncent_Altera
wilson1977
The upper slice style has a buffer.
Wincent_Altera
Hi Wilson,
That why it is depends on your application/needs.
Let me know if you have further question.
Wincent_Altera
wilson1977
But,the upper code is commented.
Can it work after uncommented?
Wincent_Altera
Hi Wilson,
Based on the code , it seen to be different usage. The existing code shall be sufficient enough to test the overall performance.
If this code is something compulsory to you. The best way to confirm this is to re-run the compilation (after uncommented).
IF you seeing any issue on the compilation, please let me know , we can work together to solve this.
Wincent_Altera
Wincent_Altera
Is there anything else you think I could help you ?
Wincent_Altera
Wincent_Altera
Let me know if you need more time to response to this cases.
Wincent_Altera
Wincent_Altera
Given that there is no further reply from you after a few follow up, I sincerely hope you had solve the problem.
Please be understand that we are in full commitment to ensuring all of our client success.
IF you happen to get back to this issue and it is still not resolve, please submit a new thread, We will be there for you.
Wincent
