A10 voltage conversion
TGao
Hi
BecauseA10 3.0 IO is not enough, can I use max10 for voltage conversion?
If Yes,How(3V-1.8V)? Thanks
Ted​
Rahul_S_Intel1
Hi Ted,
If I understand your question correctly , you need have voltage IO standard conversion IC, I am recommending to use the voltage conversion IC, If you are using MAX 10 , IO standard have to set according to your design
TGao
HI Rsree,
Noted it . Thanks!
Ted
