- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I use the DE10-NANO since one year with success. Now I tried to do some opencv over python and updatet some apis for that. After doing that immediatly the HDMI output didn't work any more. Because I thought it wasd because of the update I changed to my MISTER-SDCARD which worked always fine. This i did use as before, but HDMI didn't work. Is the HDMI-Port damaged or may it be that the code in one chip has been changed and should be reseted by an special command. Has anybody an idea?
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Did you try to make a fresh card based on a fresh download of the image supplied via the terasic site? There is a golden reference application that should work. Terasic also provides very good manuals how to make sd cards that boot properly.
Br.
Johi.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks for your hints. But thats what I did. I did put a view different images to sd-cards and tried them. This sdcards boot, but don't give an output to the hdmi-screen. I can use ssh to connect to the board and get the linux shell. I can use it very well. Perhaps I will try also the Angstrom-distribution. Perhaps there is an application, which can reset some microcode for the hdmi-output? If I connect with ssh -X I can start the reference applications and they work fine with the remote X11-monitor. So I need a special application for hdmi-tests.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you. I just did sent an email to TERASIC and two days before I did send a mail to the german distributor digikey, but they didn't answere till now.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you. I have contacted them and there is a HDMI RX-TX Example I tried. But theyhave some more ideas and I hope they will work finally
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Good luck!
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
